Re: Selinoid just clicks
Posted by deanostoybox on April 03, 2019 at 18:29:41 [URL] [DELETE] :
In Reply to: Selinoid just clicks posted by John on April 03, 2019 at 14:58:12:
Assuming it is an 8N you are talking about (has a solenoid and this is an N board) sometimes the starter will stick. If you put the tractor in 4th gear and rock it back and forth with the tire that will usually pop the starter loose. I have had to loosen the starter bolts and tip the starter away from the flywheel once for a friend when that happened to him near a creek and a big rain was expected. We could not rock the tractor because a heavy implement was on the ground.
I would not expect the tractor dying to be related to the starter issue.
Just a thought.
