Re: Zenith Carbs
Posted by Larry on April 04, 2019 at 13:50:18 [URL] [DELETE] :
In Reply to: Re: Zenith Carbs posted by Ultradog MN on April 04, 2019 at 07:20:50:
Thanks I see that adjustment screw now. When I got the tractor it was overhauled and painted like new. Painted the carb blue also. I thought that was a bolt since it had all the paint on it. The spring part was covered in paint. I'll try the adjustment now. If needs be I'll take it off and clean it up like you advised. It seems to run fine when working at 1/2 or 3/4 throttle. Not much info out there that I could locate on the net. Thanks again.
