Re: Krammin
Posted by Charles on April 09, 2019 at 17:32:06 [URL] [DELETE] :
In Reply to: Krammin posted by Charles on April 09, 2019 at 07:03:54:
Got the pin out. Its threaded on back mount. Keeper bolted on front mount keeps it from turning loose. Just have to remove stop and unscreW from exosed slots. Poorly design original uses tHE threaded portion for the bearing support. Wear is at least 1/16 to 1/8' DEEP IN THIS THREADED AREA. Onlt about 1/8" screwe in rear mount . Pin needs to be about 1/2" longer so bearing is on unthreaded portion. I may get by with just having a new pin made. Need to mic bearings yet. Even appears there may be enough space to pull bearing, without tearing front apart. Would have been nice if I had a machanics book.
Commeb
ts appreciated. Live and learn!!
