Re: Front axle wear problem that should be looked into by 600
Posted by Charles on April 12, 2019 at 08:34:02 [URL] [DELETE] :
In Reply to: Re: Front axle wear problem that should be looked into by 600 posted by K.LaRue-VA on April 10, 2019 at 20:45:11:
I can get from. Royse Larson, The front slide out axle from one of his 8N's or a Jubliee. He and I feel they may be Interchanable, especially jub as it may be same length of wishbone to transmission housing mount. The hole front axle of Jub might be the same as 600 (threaded swivel pin). 4 bolts hold front end to motor mount (e-bay $380)
Any one pipe in on model changes, in this area.
Today I will try and get my pins out and assess damage. Me think a starnard bolt and coffee can shims will restore to original. My spindle and hubs are ok.
