Re: Need Help With Thread Inserts.
Posted by Kimberly on April 12, 2019 at 10:06:43 [URL] [DELETE] :
In Reply to: Re: Need Help With Thread Inserts. posted by TheOldHokie on April 12, 2019 at 09:34:46:
There is a Fasternal not too far from me. I thought I would visit to see if they had what I need. Whatever you recommend for this application. Not a lot of thread depth in this hole. Someone in the past may have gotten too aggressive trying to stop a leak; or the bolt just worked loose and then getting up and down on the tractor keep wiggling the bolt. Whatever the reason, I now have to repair it. It was leaking bad on the inspection cover side; I haven't ran the tap through them yet but suspect that some threads may be damaged and it couldn't be tighten properly to prevent the leak.
