Re: Need Help With Thread Inserts.
Posted by R Geiger on April 12, 2019 at 12:12:33 [URL] [DELETE] :
In Reply to: Re: Need Help With Thread Inserts. posted by Kimberly on April 12, 2019 at 10:58:51:
A helicoil repair is pretty straight forward, when you install the insert you will have a little tang that is used to turn in the insert. You will have to break that off. I use a punch, but don't lose it inside the housing.
you might drill and tap a hole to practice with.
