Re: Miss diagnos and change plan
Posted by Charles on April 12, 2019 at 17:33:03 [URL] [DELETE] :
In Reply to: Miss diagnos and change plan posted by Charles on April 10, 2019 at 11:58:23:
OP's
Should read drill to 23/32" or 47/64 and ream to .750 and then press in.
Error was made as my other option was to drill all to 25/52" and buy 20 English bolt 120 MM long. This option wold still allow the softer cast axle to wear again as compare to bronze bushing and be with a couple thousand play.
I did the above on hydraulic arm wear. Had to heat knuckle with acetylene and cool in outdoor furnace to aneal softer to drill.
cost of bushed axle would have been about $180.
Charles Krammin
