Hard to turn over
Posted by Bob Francis on April 18, 2019 at 18:53:17 [URL] [DELETE] :
I have a 49 8n, 6V. I have never had any trouble starting it until a few days ago. I had just driven it a few days before. It had seamed kind of sluggish on the start. I was thinking battery. I have not replaced the battery and I have had it for about 6 years. The starter ran down to a stop I pulled the battery ant took it to the garage. The tractor sets in a tent shed, that is just about as far as I want to carry a battery. Hooked it up and it looked good. let it charge a bit, then put it back in. Cleaned and shined every thing in the prosses. It still would not turn over. I brought the truck down and jumped the starter with 12V nothing. Something is wrong. If I turn the motor with the belt I get a tight spot, then it will roil slowly to the next tight spot. Took plugs out, they are dry. It turns over a little better with all the plugs out, but not near what it should with the 12V. No water pumping out of the plug holes. Thanks for you help and thoughts.
Bob
Francis
