Re: paint
Posted by Tim Daley(MI) on April 22, 2019 at 07:25:02 [URL] [DELETE] :
In Reply to: paint posted by Larry Holbrook on April 22, 2019 at 05:54:21:
The one who would know the correct shade is Ultradog; he is the resident Thousand Series expert. The blue/white paints changed over the years. A '74 Model would be New Holland I believe. If the tire was loaded with Calcium Chloride and leaked, you might consider draining it and then getting the rims cleaned and repainted, tires washed out and new tubes installed. Painting over oil or Ca Chl is only going to mask the stuff for a short time. The paint TSC sells now is MAJIC brand and garbage in my opinion. They use to stick and sell the VALSPAR brand which is a decent alkyd enamel. Once it is determined which paint code you need, your local CNH dealer may be the first option to shop at.
Someone sent me these a while ago...
Ford Tractor Blue (1962)------------------------------12720
Ford Tractor Blue (1963-1965) - M20J1639A-------------12809
More Ford Tractor Paint codes
Ford Beige--------------------------------------------33186
Ford Gray---------------------------------------------30570
Ford Gray---------------------------------------------32663
Ford Gray (1948 & 1954)-------------------------------32675
Ford Yellow-------------------------------------------82536
Ford Light Yellow-------------------------------------82549
Ford Red----------------------------------------------2833
Ford Red (1947)---------------------------------------70075
Ford Light Red----------------------------------------72598
Ford Equipment Dark Blue------------------------------12908
Ford New Tractor Red----------------------------------71969
Ford New Tractor Silver-------------------------------33442
Ford Tractor Buff-------------------------------------81339
Ford Tractor Gray-------------------------------------30448
Ford Tractor Gray (1965) - M20J1750-A-----------------32571
Ford Tractor Gray (1965)------------------------------32571
Ford Tractor Green------------------------------------42940
Ford Tractor Yellow (20J3132A)------------------------82179
Ford Tractor Yellow (New) (M2J5394-A)-----------------82291
Ford Tractor Orange Red-------------------------------71346
Ford Tractor Vermillion (1949)------------------------3155
Ford Tractor Vermillion-------------------------------70205
Ford Tractor White------------------------------------8712
Ford Tractor & Implement Buff #1640 (1967)------------22914
Ford Tractor & Implement Buff (1967)------------------4068
Ford Tractor & Implement Buff (1967)------------------4119
