Re: Plan for removing rear wheel - advice needed
Posted by TheOldHokie on April 22, 2019 at 18:36:55 [URL] [DELETE] :
In Reply to: Re: Plan for removing rear wheel - advice needed posted by Kimberly on April 22, 2019 at 17:16:53:
Come along and tie down strap should work fine. I am no muscle man but I can stand an unloaded tire up with no problem. It may be a grunt but I suspect you can as well. The real issue is getting the darn thing lined up with the studs when remount it. Has to be clocked almost perfectly.
TOH
