Re: paint
Posted by Ultradog MN on April 23, 2019 at 06:34:36 [URL] [DELETE] :
In Reply to: Re: paint posted by Larry Holbrook on April 23, 2019 at 05:02:06:
Thanks.
By the way,
If you look close you can see the inside of the rim is a slightly different color.
One quart for two coats on both rims and centers wasn't going to be quite enough paint. So on the insides of the rims I wasn't concerned with the color and painted the second coat with some left over Hundred Series gray that I had.
These are 38" rims so one quart will easily do the outsides of your 28s.
