Re: Damage to Differential - Will this be OK? Photos included
Posted by TheOldHokie on April 28, 2019 at 03:39:41 [URL] [DELETE] :
In Reply to: Re: Damage to Differential - Will this be OK? Photos included posted by Kimberly on April 27, 2019 at 23:11:32:
It isnt velocity. When the differential gears jam very bad things happen. Wish I had taken a picture of the big hole in the case of the differential on my Ram 1500. That failure was caused by a pinion nut that worked loose and the pinion jammed in the ring gear. It looked like it had been hit by an RPG...
TOH
