Re: PTO Pump
Posted by Dean on April 29, 2019 at 12:56:41 [URL] [DELETE] :
In Reply to: PTO Pump posted by Del Huebner on April 29, 2019 at 12:15:27:
That looks like the identical roller pump that I have on my three point mounted sprayer.
If so, you will need a pressure regulator and provision to return water to the tank when the discharge nozzle is closed. Otherwise you will dead head the pump.
If you never close the discharge while the PTO is on, simply connect the inlet to the bottom of the tank and the outlet to the discharge hose.
Dean
