Re: Zenith Carberator
Posted by Larry Holbrook on May 03, 2019 at 04:57:26 [URL] [DELETE] :
In Reply to: Re: Zenith Carberator posted by Larry Holbrook on May 02, 2019 at 18:21:24:
Ok thanks for the info. I would just as soon it had the Holley on it. I didn't switch it but it came that way when I got it. The only thing that is adjust able on the Zenith is the Idle air mixture. The main jet is fixed. I'd just clean it up and rebuild it but the crack is not repairable. Gas just runs out of it very slow. Took a good look to find it. I'm going to order the one at Yesterdays Tractors and hope for the best. If I could I'd get a Holley for it but I'm sure that the linkage would be different. Maybe I'm wrong on that. Just an assumption that those would be changed.
