Re: Zenith Carberator
Posted by K.LaRue-VA on May 03, 2019 at 10:29:48 [URL] [DELETE] :
In Reply to: Re: Zenith Carberator posted by Larry Holbrook on May 03, 2019 at 04:57:26:
The Zenith carbs were supposed to be a direct replacement that bolted right on and hooked to the same linkage. If the linkage does not match up it is probably the wrong carb and it may be difficult to get it to work right with the governor/choke/throttle. Many of the less expensive replacement carbs are "zenith style" or "Holley replacement". The build quality on those unbranded replacements is often pretty bad.
