Re: Starter switch on NAA
Posted by R Geiger on May 04, 2019 at 12:41:20 [URL] [DELETE] :
In Reply to: Starter switch on NAA posted by countryguyVT on May 04, 2019 at 08:25:34:
The top cover has to be removed in order to change out the switch. at the rear of the cover is a tab that covers a spring and check ball. make sure the spring is not lost inside the trans or elsewhere. Replace cover gasket. not a hard job at all.
