Re: Setting Differential Bearing Preload on 9N
Posted by R geiger on May 04, 2019 at 19:58:59 [URL] [DELETE] :
In Reply to: Setting Differential Bearing Preload on 9N posted by JP on May 04, 2019 at 09:19:40:
I would go with the original gasket. FO-4 calls out the correct procedure for differential bearing setting.
What JMOR is saying is for the axle bearings, not the differential bearings.
