Re: Setting Differential Bearing Preload on 9N
Posted by Den N Ms on May 05, 2019 at 16:47:08 [URL] [DELETE] :
In Reply to: Re: Setting Differential Bearing Preload on 9N posted by JMOR on May 04, 2019 at 16:01:15:
Jmor,You said,Now remove one shim/gasket at a time until the other tire rotates opposite direction to the one you are turning (now ends of axles are not binding, by just a few thousandths). Apply sealer and button it up.
And I know you meant,Now (ADD) one shim/gasket at a time until the other tire rotates opposite direction to the one you are turning (now ends of axles are not binding, by just a few thousandths). Apply sealer and button it up.
