Re: Ford 620 tractor question...
Posted by TheOldHokie on May 07, 2019 at 06:01:29 [URL] [DELETE] :
In Reply to: Re: Ford 620 tractor question... posted by Josh in RI on May 06, 2019 at 20:53:12:
My experience does not extend to a tractor like this. My guess is the engine still has provision for mounting the OEM pump but the camshaft drive gear may not be present. Installing one would require some work. Hanging a crankshaft driven pump on the front is probably easier and you would not be limited to the rather low flow rate of an OEM style pump. Either way you would have to find and plumb a hydraulic sump. The OEM supply lines are not going to be present. All very doable but it would be a real "project".
TOH
