Re: Very weak hydraulic lift ford naa golden jubilee
Posted by Francois Cote on May 07, 2019 at 09:38:02 [URL] [DELETE] :
In Reply to: Re: Very weak hydraulic lift ford naa golden jubilee posted by TheOldHokie on May 07, 2019 at 08:10:11:
Thanks for your reply TOH!
My pumpis also running a log loader trailer through a hydraulic outlet, and is working ok but does “screech” once in awhile when heavy lifting. I would think the log loader is as demanding as lifting an implement, so I would conclude like you that it is either the cylinder or the relief valve. Do you think the relief valve could be accessible through the hydraulic cover as well if I took it off while looking at the cylinder?
Thank you for your response,
Francois
