Re: Very weak hydraulic lift ford naa golden jubilee
Posted by TheOldHokie on May 07, 2019 at 16:32:32 [URL] [DELETE] :
In Reply to: Re: Very weak hydraulic lift ford naa golden jubilee posted by Francois Cote on May 07, 2019 at 09:38:02:
The relief valve will be ahead of the the hydraulic outlet. The "screeching" is usually the sound produced by a relief valve at over pressure conditions. If you have good pressure at the hydraulic outlet but not at the 3pt I would suspect the 3pt lift cylinder or plumbing is leaking/bypassing.
TOH
