Re: Leaking ford jubilee
Posted by BlasterStumps on May 11, 2019 at 21:55:09 [URL] [DELETE] :
In Reply to: Leaking ford jubilee posted by Will on May 11, 2019 at 20:19:59:
If it has damage to the block, head or head gasket, chances are you will see bubbles in the radiator coolant while it it running (after it warms up to temp if it has a t-stat).
Check the engine oil also to see if it is milky or clear oil.
Maybe the owner washed it ??
Best of luck with it.
