Re: Leaking ford jubilee
Posted by aayneIA on May 12, 2019 at 04:25:30 [URL] [DELETE] :
In Reply to: Leaking ford jubilee posted by Will on May 11, 2019 at 20:19:59:
The left side of the engine being oily is a good indication of a bad valve cover gasket. Remove the two acorn nuts on top of the valve cover and the cover will roll out toward you after you remove the sediment bowl.
