Re: down loading manuals
Posted by TheOldHokie on May 13, 2019 at 09:41:01 [URL] [DELETE] :
In Reply to: down loading manuals posted by Ward Holloway Sr on May 13, 2019 at 08:48:56:
Depends. If you have something in particular you want tell me what manual it is and I will give you specific instructions.
In general most of the manuals in the library are Adobe PDF documents. In the index they have a "PDF" link at he end of the name. For those, on a Windows PC place the cursor over the PDF link and right click the mouse. A drop down menu will appear - select "Save Link As..." from the choices. That will open a dialog box on your PC and you can chose the file name and where you want the manual saved.
Some things like ad brochures are in HTML and JPEG image format and that requires a different procedure depending on exactly how the document is formatted.
TOH
