Re: Problems with Points
Posted by duey on May 20, 2019 at 17:12:52 [URL] [DELETE] :
In Reply to: Problems with Points posted by K.LaRue-VA on May 20, 2019 at 11:06:21:
It would be fun to know what the amp gauge does when trying to start it after it dies.. do you get the normal discharge cycling indication... does it show a steady discharge with no fluctuation....
The wiring does get disturbed a minor amount when fiddling with the points... also the condenser wire... as well as where the power comes IN to the distributor...
Keep a broad view of things..Good Luck solving your mystery :-)
