Re: 8N-C hydraulic pump driven from front
Posted by Chris Zuhn on May 20, 2019 at 18:50:29 [URL] [DELETE] :
In Reply to: Re: 8N-C hydraulic pump driven from front posted by TheOldHokie on May 17, 2019 at 05:31:50:
Thanks for the information. I have a pump I took off my (now scrapped) 4.236 Perkins. Splined shaft, but I don't know the specs, offhand. Used it with a pressure relief valve to operate the power steering on the 1980 Ford F150. Possibly a back hoe, and am considering running the brush cutter via hydraulics instead of the PTO. Both of these projects are in the middle future, however. The engine-mounted pump will give me "live" hydraulics, and still be able to use the 3-point hydraulics independently. Trying to not re-invent the wheel; your information has pointed me in the right direction. Thanks. zuhnc
