Re: Problems with Points
Posted by Dn-N-Tn on May 22, 2019 at 10:36:04 [URL] [DELETE] :
In Reply to: Re: Problems with Points posted by JMOR on May 20, 2019 at 13:11:34:
About 30 years ago, a neighbor was having trouble with dust in the Distributor and premature point failure on his 52 8N. If memory is correct, I cut the bottom out of a plastic, gear oil squeeze bottle, about 1/2-5/8" from the bottom--cut a hole for the shaft and made sure it cleared the rotor button, and covered the points and condenser in the distributor. After that, we'd replace the points about every five years. This was a cheap fix, but it worked, Dennis
