Re: positive grnd cable
Posted by cage on May 30, 2019 at 19:07:43 [URL] [DELETE] :
In Reply to: Re: positive grnd cable posted by JMOR on May 30, 2019 at 09:35:43:
thanks for the pic, the connection to the dash/hood bolt just didn't make sense. An 11" ground strap (measured tip to tip) was to short to reach the + terminal of the battery to the tool box bolt. A 5/16" hole located just above where the wiring harness passes into the gauge area fits the cable length quite well and is what I will use.
