Re: Troubleshooting hydraulic lift and lower
Posted by JMOR on June 03, 2019 at 10:41:22 [URL] [DELETE] :
In Reply to: Troubleshooting hydraulic lift and lower posted by Steve Pfost on June 03, 2019 at 10:00:50:
If control valve is free to move and the friction plate on touch control lever is adjusted to offer no friction, then the only thing you will feel at touch control lever will be the stretching of the fork retracting spring as you move toward Lower. The same spring is working to help you move the lever toward Lift (relaxing the stretch).
