Re: Troubleshooting hydraulic lift and lower
Posted by Steve Pfost on June 03, 2019 at 11:29:30 [URL] [DELETE] :
In Reply to: Re: Troubleshooting hydraulic lift and lower posted by K.LaRue-VA on June 03, 2019 at 11:21:29:
I removed the castle nut before the video and the. Retightened it. The friction disc seems to be fused to the lever and I was trying to listen and tighten it back up. It moves with the lever. And those numbers, do you mean 2-5/8 from the very top or from where the opening for the wing nut begins. Is the quadrant adjustment something that has to be performed on the regular due to regular movement of the lever and vibrations of the tractor?
