Governor Settings
Posted by Rick D. on June 03, 2019 at 21:16:34 [URL] [DELETE] :
i have likely over complicated this: When the 8n is at idle is the throttle governor arm with spring at the 12 oclock position? i cannot get the idle to be below 800 unless i disconnect the linkage. i do need to check the preload on the spring but need to check again.
thanks
