Re: Sherman Trans Hole Template
Posted by K.LaRue-VA on June 12, 2019 at 08:52:46 [URL] [DELETE] :
In Reply to: Sherman Trans Hole Template posted by Joel W on June 10, 2019 at 13:14:55:
I don't trust a template or measurements to do more than drill a small pilot hole to figure out where the real hole needs to be. At least when measuring the actual transmission you are installing it removes the error of having a template or measurements for the wrong transmission. Seems like the instructions for installing the Sherman said to wait and determine final size and location of the hole after the Sherman was installed in the tractor.
