Re: 9N Axle won't go all the way in
Posted by JP on June 15, 2019 at 15:23:47 [URL] [DELETE] :
In Reply to: Re: 9N Axle won't go all the way in posted by John in Mich on June 15, 2019 at 14:55:59:
It turns out it was hitting the other axle shaft which had pushed in when this one was removed, which took the preload off the bearing. I jacked up the other side so the wheel was off the ground then slowly used two bolts to pull the axle in which pushed the other axle back into place and preloaded both bearings. The wheels are now starting to turn in the same direction when rotated so I think I'll add a shim/gasket to take a bit of the preload off which should allow the wheels to turn in opposite directions.
