Re: Valve seat
Posted by Rustyal on June 17, 2019 at 06:55:10 [URL] [DELETE] :
In Reply to: Valve seat posted by Michael on June 16, 2019 at 10:16:33:
After you lap them and assemble the valves you can check for leaks. Use a couple drops of water and see if it drains thru. The seats can be replaced. If you a skilled grind them you should be okay.
