Re: 8N Steering Wheel
Posted by Lynn Patrick on June 20, 2019 at 08:24:01 [URL] [DELETE] :
In Reply to: 8N Steering Wheel posted by Larry Frechette on June 20, 2019 at 06:19:34:
I have used a large 3 arm puller by removing the 3 prongs & just using the straps. Hard to describe, but my puller has 2 straps for each prong. Remove the prong, lower until you can put the straps past the steering wheel arms & bolt under the arms. That pulls from the arms, not the center.
Don't know what to tell you about the hollow shaft. Maybe leave the burr on loosely & a small bolt in the hole??
