8n lift question
Posted by Mike-Ga on June 24, 2019 at 11:07:48 [URL] [DELETE] :
Ford 8N, lift will lift and hold with engine off a while (seems strong). (the following is with an implement)= When position control is lifted over 1/4 up from bottom, lift raises to top (regardless if you push position control back down) and when it reached the top, it "releases" and goes back down to a reasonable height depending on where the position control is at that time. It acts similarly it draft or position control with a little more position control in the lower quadrant only when in position control mode (and not draft). Any assistance is appreciated
