Re: starter issue
Posted by R Geiger on July 11, 2019 at 21:39:15 [URL] [DELETE] :
In Reply to: Re: starter issue posted by Thad on July 10, 2019 at 09:07:24:
With the tractor out of gear ground the small terminal and see what happens. If you have it in gear and are standing in front of the tire, you may get run over. It almost sounds like the switch is not working or you have a bad solenoid right out of the box. It happens!
