Re: No fire 8n
Posted by Bruce(OR) on July 14, 2019 at 19:40:48 [URL] [DELETE] :
In Reply to: No fire 8n posted by Victoria on July 14, 2019 at 18:59:38:
Generally if your running the 12V system, you don't need the ballast resistor.
That coil should be marked "Internal"resistor". Is it?
Voltage meter is now in need. Ground to ground and chase the voltage going into the switch, out of the switch and to the coil, Does it?
As your running a 12V system, I might start with a known good 12V coil with built in resistor if all checks out.
