Re: removal of rear wheel center disc
Posted by Farmer Dan on July 17, 2019 at 15:21:09 [URL] [DELETE] :
In Reply to: Re: removal of rear wheel center disc posted by paul appleton on July 17, 2019 at 14:52:01:
I'm thinking the center disc is rusted to the hub. Make a mixture of half transmission fluid and half acetone, pour this in between the disc and hub and let it set over night. Butane torch ain't a lot but it might just be enough if you get lucky. I don't have an acetylene torch either and I've made it this far ;-)
Just keep putting that penetrating oil mixture on it every couple hours and then in the morning give it a try again with the big hammer and little torch.
