Re: Testing starter
Posted by Jack - Iowa on July 19, 2019 at 20:21:22 [URL] [DELETE] :
In Reply to: Re: Testing starter posted by thad on July 19, 2019 at 18:50:21:
Thad,
The automotive type will not work.
On the tractor solenoid the coil operating voltage is obtained internally. The starter switch then grounds the other end of the coil.
ON the automotive type, the operating voltage is fed from the starter switch and the other end of the coil is grounded internally.
Cannot use the automotive type unless you add a dashboard pushbutton and defeat the transmission safety feature from working.
