Re: Tim Daley - email didn't accept my reply
Posted by Tim Daley(MI) on July 29, 2019 at 07:01:30 [URL] [DELETE] :
In Reply to: Tim Daley - email didn't accept my reply posted by Israel on July 28, 2019 at 11:24:45:
Did you get all the pictures I emailed? If not I suspect that is your message. Did you get all the text? Part of your problem is your generator is not a Ford Tractor unit. It's Ford but an early V8 style. There should be no vent openings on the tractor unit. The 3rd Brush has an adjuster screw on the back end plate from HI to LO. There is no FIELD post on it. ALL 9N & 2N models used the 1-Wire, A-Circuit Design, 11 amp output generator after s/n 12500. They also must use the round-can cutout circuit mounted in the back of the dash on the steering column. By the way, ALL 9N & 2N models used a 1-wire starter with no SOLENOID. Solenoids weren't released until the 8N model in 1947 and also eliminated the cutout and opted for a square Voltage Regulator.
9N & 2N ELECTRICAL after s/n 12500:
2N10000 FORD TRACTOR GENERATOR:
