Re: Spacer between lower crank pulley and frame
Posted by Lynn Patrick on July 30, 2019 at 08:23:02 [URL] [DELETE] :
In Reply to: Re: Spacer between lower crank pulley and frame posted by Lynn Patrick on July 29, 2019 at 08:13:23:
I should have mentioned - What you have is probably the front pump drive. The one I took off has a spline drive center.
