Re: oneill
Posted by TheOldHokie on August 06, 2019 at 06:28:47 [URL] [DELETE] :
In Reply to: oneill posted by joe on August 06, 2019 at 04:16:10:
A modern SAE 10W30 is a good all season match for the original seasonal grade recommendations.
Standard 50/50 mix of ethylene glycol antifreeze. Dont overfill or it will puke it back out.
Leaking at the valve stem indicates hole in the tube. At a minimum that needs to be repaired. If the leak has persisted for a while it may have caused rust damage to the rim which may or may not be repairable. Break the tire down and inspect and repair as indicated.
TOH
