Re: Spacer between lower crank pulley and frame
Posted by Dennis on August 06, 2019 at 17:29:24 [URL] [DELETE] :
In Reply to: Re: Spacer between lower crank pulley and frame posted by Lynn Patrick on July 30, 2019 at 08:23:02:
Thanks for the information, I know when I took the pump off the front there was a splined shaft I took out and didn't look good between the frame and the pulley. The belt looks good but in case I have to change or replace if it breaks I know what I will have to do.
