Re: 8n seat spring mounting studs
Posted by Dn-N-Tn on August 06, 2019 at 20:15:19 [URL] [DELETE] :
In Reply to: Re: 8n seat spring mounting studs posted by Doug on August 06, 2019 at 19:17:02:
If the threads aren't rusted and stuck too bad, you might get it out with an extractor. If not, you can still weld it 1/8" below the surface by striking the arc on the broken stud first, build it up a little, then weld the hole up with a deep penetration.
