Re: Steering wheel replacement
Posted by K.LaRue-VA on August 07, 2019 at 13:27:09 [URL] [DELETE] :
In Reply to: Steering wheel replacement posted by dave#1 on August 07, 2019 at 12:19:45:
I recently bought a replacement steering wheel from the clearance rack in TSC marked $4. I couldn't pass it up. It was a keyed version, so I thought it would work on my 2N. As usual, it required modification. The inside diameter of the taper was too small. I had to work it over with a rat tail file before it would slide on far enough to tighten the nut.
