Re: 1953 NAA
Posted by Kirk-NJ on August 09, 2019 at 04:08:02 [URL] [DELETE] :
In Reply to: 1953 NAA posted by Terry on August 08, 2019 at 13:40:22:
The serial number you have posted is an NAA 1954 number not a 1953 Jubilee. Some sellers will switch the badges out for the more sort after Jubilee, which in your case didn't happen. The only other way it could be a jub is if someone switched out the tranny and you would have a serial number on the engine just below the front of the manifold. In these case you could have two sets of serial numbers Or some could have no numbers at all depending what was switched out.
