Re: Ford 8n Front loader Control Rebuild kit
Posted by Josh on August 09, 2019 at 06:37:05 [URL] [DELETE] :
In Reply to: Re: Ford 8n Front loader Control Rebuild kit posted by Frank (WNY) on August 09, 2019 at 05:15:23:
I'll have to keep this in mind. I ended up buying the ebay listing. The guy is only 2 hours from me and he said that if it leaks then I can return it as long as I don't crack it open or modify it so I'm going to give that a shot first and see what happens. Fingers crossed that resolves my issue and then I can search for a rebuild kit for this or tear it open and use it as a learning opportunity to find thee worn seal and resolve it myself and possibly have a backup.
Are you sure that the link you sent is the correct control? My control has 5 hoses going into it, 4 go into rams and 1 goes into the tank.
