Re: snowplow ?
Posted by Ultradog MN on August 10, 2019 at 04:50:48 [URL] [DELETE] :
In Reply to: Re: snowplow ? posted by Ultradog MN on August 10, 2019 at 04:26:28:
A little more info:
The mounting frames changed over the years. There was one for Ns, a rear axle push for NAA/Jubes and Hundreds the hydraulic lift type for the Hundreds and they made a push frame for the 3 cylinder 2000/3000s too.
However, the blades - both the dozer blade and the true snow plow blade - are all interchangeable through the years and one from the 1940s will fit a 1970s push frame/tractor.
