Splitting an 8N
Posted by Cal Sexsmith on August 17, 2019 at 13:21:14 [URL] [DELETE] :
I am splitting my 1948 8N to replace the ring gear. I have been following the instructions on Kevin LaRue's page. All has been going well so far, but I have just hit a snag. Kevin says that it is not necessary to remove the hood. He suggests removing the bolts holding the steering box to the transmission case and then lifting the steering box to clear the flange at the joint. This worked, but now the left hand steering arm won't clear the starter drive protrusion on the transmissin case. Should I lift the steering box another 3 or 4 inches? or is there another solution.
